The engine will start but won’t hold idle for too long. It holds idle for about 10-15 seconds, and then it’ll die out. So I tried giving it some gas while it was idling but all that did was cause the engine to die out faster.
I’ve changed the fuel filter, fuel pump, PCV valve, spark plugs, dashpot diaphragm, and even made sure the main relay is in good working order. I’m out of ideas at this point. Any suggestions.
SPONSORED LINKS
Monday, June 22nd, 2009 AT 5:52 PM
