The rear vents are not blowing air at all and while the front dashboard vents still blow cold air, the levers that change the flow direction are broken. The dealer wants several hundred dollars to replace the broken flow directors. Can I do this myself? How do I take the vents apart? Could the flow to the rear vents be disconnected?
Any advice is appreciated.
Aug 18, 2010 at 12:10 AM
