2002 Acura MDX Temperature control
ANDRE VELIAN
  • 2002 ACURA MDX
  • 6 CYL
  • FWD
  • 67,000 MILES
My MDX ceased holding the temperature. Sometimes when the temp is set, let's say at about 70 degrees, it will get colder than 70, then the heat will come on.
It never did that before.
Thursday, January 3rd, 2008 AT 7:56 PM
JEREMIAH
  • 217 POSTS
You might have a problem with your air mix motor, its what blends the hot air from the heater and cold air from the a/c to get the exact amount of temperature, you particular vehicle model has had a few of those problems lately.
Aside from that, make sure you manually have the a/c set to off when you set the temperature gauge to full auto, it usually goes on to prevent your windows from fogging but it also throws off the vent's output temperature
Tuesday, April 15th, 2008 AT 5:43 PM
