2002 Acura MDX Heater Blows Cold Air
2002 ACURA MDX
MEGMAS
Heater problem
2002 Acura MDX Automatic 48000 miles
My 2002 Acura MDX started blowing "COLD" air today even though I had been driving for some time and had the temp set at 90. I'm taking it in tomorrow to have it looked at, but wanted to know if you had any ideas and how much (range) it may cost.
Thanks!!!!
Mar 12, 2009 at 10:45 AM
When the last time you've replaced the thermostat-not sure replace it and see what happens
Mar 12, 2009 at 12:11 PM
MEGMAS
I forgot to mention: Whne the back Heater/AC is placed on manual, heat does come out into the backseat, still ice cold air, at my feet, in the front.
Mar 12, 2009 at 12:16 PM
This problem can be anything from thermostat/heater core clogged-up/Aix mix/blend/mode problems to include vacuum and actuator operating devices
Mar 12, 2009 at 12:49 PM
