2001 Acura MDX temperature display backlight not working
2001 ACURA MDX
86,000 MILES • 6 CYL • 4WD • AUTOMATIC
IHSIN
hi there,
The back light of my 2001 Acura MDX's temperature display (the small display in the middle of front panel) is not working any more. The display still works, as I can adjust up or down the temperature and the display shows the change. The problem is the back light of the display, so at night I can't see the reading any more.
Is this just a matter of replacing some bulb? I can't find any info in the owner's manual.
Any info/pointer appreciated.
Thanks
David
Feb 1, 2008 at 4:52 AM
JEREMIAH
  • 217 POSTS
yes it is a simple bulb problem and it won't be in the owners manual.
replacing it only takes 5 minutes but you have to remove the display,2 vents and brown trim panel as one piece. it's held on by clips
Apr 15, 2008 at 11:08 AM
