1993 Acura Legend replacing the head gaskits
NATRAM
Engine problem
6 cyl Front Wheel Drive Automatic 161900 miles
How do you remove the intake manifold?
Dec 14, 2007 at 7:43 AM
BRUCE HUNT
  • 3,754 POSTS
You will need to disconnect the fuel lines to the injectors and some other stuff but the bolts or nuts should be pretty simple to find except that they is probably a bracket on the bottom the you need to tackle from the underside.
After you get it off, make sure the gasket is COMPLETELY removed and replace with a new one. A leak on the intake will haunt you with other problems.
Dec 14, 2007 at 8:47 AM
THEBIGGMCDOG
  • 25 POSTS
replace the engine, get. a use japanese engine it will be more cheep
May 26, 2008 at 5:11 PM
