1992 Acura Legend cruise control
TSTOTLER1975
  • 1992 ACURA LEGEND
  • 6 CYL
  • FWD
  • 112,000 MILES
My? Is when I push the cruise control button there is a light on the button that turns on but the light that is in the gauge cluster dose not light up and the cruise dose not set do you have idea what it might be or know away to fix it.
Monday, September 22nd, 2008 AT 7:43 PM
KHLOW2008
  • 41,814 POSTS
Hi tstotler1975,
The switch is not activating the cruise control and you need to check
1. Brake switch, it has a cruise control circuit, check pedal to switch clearance.
2. Cruise control switch or its wiring circuit, might be a faulty wire reel (SRS) or a bad contact plate.
3. Gear shift inhibitor switch.
Tuesday, September 23rd, 2008 AT 11:28 AM
