Always bleed air from cooling system when changing coolant.
Open bleed bolt on coolant outlet.
Fill system.
Close bleed bolt when coolant starts to run out without bubbles.
Tighten bleed bolt to 84 INCH lbs. (10 N.M). With radiator cap removed, start and run engine until normal operating temperature is reached.
Top off coolant and install radiator cap.
Suspect and Check water pump
check for headgasket failure
SPONSORED LINKS
Monday, January 18th, 2010 AT 8:47 PM
