You would need to elevate the front end of the vehicle and do so in such a way that the supports do not interfere with the removal. Then you are going to take off both front wheels and remove the CV axles. There is I believe one motor mount that will have to be removed and the engine supported from above with a comealong or the like. Bolts, hoses cables, etc.
The best thing to do is get the manual. Might find one at a parts store, this site or the library.
SPONSORED LINKS
Saturday, April 19th, 2008 AT 10:27 PM
