MY INTEGRA IS RUNNING VERY RICH IN FUEL I WASTE TO MUCH FUEL , ALSO I HAVE FUEL MIX IN WITH OIL AND TO MUCH SMOKE COMMING OUT OF EXHAUST
Aug 28, 2007 at 12:23 PM
Pull the spark plugs one at a time and look for a sooty black plug. Replace the fuel injector on that cylinder, since a leaking injector can drip fuel into the oil after shutdown and also cause a rich mixture and exhaust smoke while running.
The owner reports an Acura Integra running very rich, using too much fuel, mixing fuel into the oil, and producing excessive exhaust smoke. The expert suspects a badly leaking fuel injector and recommends checking the plugs one at a time for a fouled, sooty black plug, then replacing the injector on that cylinder.
