Please note my engine and my shift gear is a b20b .
I have a b18b1 intake manifold. some part are unkown(throttle body ,iacv).Probaly a b18b engine computer...How find the computer type???
I need a computer for b20b or b18b???
I have zero brake fluid leak
If I press one time on brake pedal no rpm change.(stay on 750rpm)
If I quickly pump the brake pedal, this cause RPM increases (750RPM TO 1100RPM MAX)
sometime when I press on brake pedal I hear a noise . sound like a vaccum leak in the brake booster or internal leak in the brake master cylinder????
throttle body and IAC valve already cleaned (2 time). I clean with brake cleaner and another time with throttle body cleaner.
Yes when I use electrical ( power windows ,light ,Rear Window Defroster ...this cause decreases in rpm (750rpm to 500rpm)
.when I move with the car on the street and I put the neutral gear the RPM GAUGE INDICATOR stay on 1000rpm or 1100rpm. When I stop completly ,and car stop move for 3 second ,the RPM decrease(1000rpm to 750rpm).
Very bad when start warm up because engine noise change and car jerk and car vibrate and the rpm indicator was unsteady
this symptom sound like car virus infected by the guy installing my engine . My check engine light not work and service coming soon light not work .Some time the check engine light get on and off . The engine installer guy said I have 6 engine error code. The guy show me oxygen sensor error code ,he said this could cause misfire. He talk about cleaned fuel injector for 60$ and change oxygen sensor....
Oct 11, 2009 at 5:38 AM
