The answer to your question is YES. I have a 1996 gs-r with a 98+ front / lights. ( Opposite of what you want )
94-97 will fit onto a 98-01, but you will need to buy a set of 94-97 head lights as it is a little different than the 98-01 even though it looks exactly the same.
If you can get a hold of some 94+ head lights, then you conversion will be painless if not then you are gona be doing some cutting ( you will not like the look of it so just avoid it)
if you havnt gotten the front end and head lights already, try a junk yard or a major shop that service nothing but honda/acura you might be able to score a set for cheap.
If you need further help let me know.
Best regards,
JL
p.S. If the above info helped you please vote/leave feedback -thanks-
Sunday, June 6th, 2010 AT 6:12 PM
