1997 Acura Integra
ICEKID
  • 1997 ACURA INTEGRA
1997 Acura Integra
How would I go about fix my egr valve on my 1997 Accura Integra.I belive it has an air leak, when it idels it constantly revs up to 2rmps and down. Im a learning mechanic and im not able to fix this problem. Any advise would help. Thanks.
Sunday, May 3rd, 2009 AT 1:29 AM
DAVE H
  • 13,384 POSTS
EGR System
The EGR system reduces oxides of nitrogen (NOx) emissions by recirculating exhaust gas into the intake manifold and combustion chambers. The system consists of the EGR valve, EGR vacuum control valve, EGR position sensor, and EGR control solenoid valve.
EGR Valve Lift Sensor
PCM calculates ideal EGR valve lifts for varying operating conditions. EGR valve lift sensor detects amount of EGR valve lift and sends the information to PCM. PCM compares this information (actual EGR valve lift) with ideal EGR valve lift. If the 2 signals differ, PCM closes EGR control solenoid valve to reduce vacuum applied to the EGR valve.
Sunday, May 3rd, 2009 AT 8:31 AM
