1995 Acura Integra i already change the main relay
CAPIRAL111
Engine Mechanical problem
1995 Acura Integra 4 cyl Two Wheel Drive Automatic
my acura integra will start with no problem and the engine runs really good while running. and i can drive as far as i can without it dying on me. but as soon as i turn it off and go to the store it wont turn on. it turns but doesnt go. i have to wait about an hour to start it again what do you think the problem is. i replace the distrubtion too and battery
Sep 27, 2010 at 2:04 PM
MADMIKE1735
  • 951 POSTS
have your starter tested.... as long as your alternator is putting out around 14 volts, and your battery is good, everything points to either your ignition, or starter.... i would start with having the starter tested...
Sep 27, 2010 at 2:19 PM
