1994 Acura Integra speed drops when driving for 30 minutes,
154,000 MILES • 4 CYL • 2WD • AUTOMATIC
ADIX2
My car speed drops when i'm driving for about 30 minutes and after that is ok. It happen when i'm driving about 65 mph or less. I have my foot still to the gas pedal. Speed drops, then i depress the pedal more to gain speed back.
In the past year I have changed spk plugs, ig coil, fuel filter,and spk plug cables.
Jul 6, 2008 at 9:49 PM
KHLOW2008
  • 41,812 POSTS
Hi adix2,
Unless you are driving on level roads without any gradients would you be able to maintain the same speed with the same throttle opening.
I don't see any problem that you have unless the drop in speed is substancial and you are not climbing up a gradient.
Jul 7, 2008 at 2:51 AM
