1994 Acura Integra RPM's jumping between 3 and 4 on highway
CROSBYNANCY
  • 1994 ACURA INTEGRA
Engine Mechanical problem
1994 Acura Integra Manual 98000 miles
It only happens 1 or 2 times a week. Last night, pretty bad.
I feels like it the engine is choking.
I have never used this website. If I feel question is answered, of course there will be a donation.
crosbynancy@msn. Com
Friday, July 17th, 2009 AT 8:52 AM
KHLOW2008
  • 41,814 POSTS
Hi crosbynancy,
When rpm runs erractically, it usually is caused by the ignition coil or ignition control module and this is an indication the distributor is due for attention.
The ignition coil would be the more likely cause. Check the distributor wire harness and connectors for bad contacts.
Friday, July 17th, 2009 AT 12:35 PM
