1992 Acura Integra whippers
1992 ACURA INTEGRA
212,000 MILES • 4 CYL • FWD • MANUAL
1992B18INTEGRA
i just went outside to move my car and i went to turn my whipers on to get the snow off the front and back of my car and when i did both wippers moved like a half inch and than they stopped and nothins works and all my fuses are fine so i didnt no if it might be both motors at the same time or if the switch went out bc it dont even let it spray water on my windows or anything
Dec 23, 2009 at 9:14 AM
  • 31,937 POSTS
Hi there,
There is only one motor, the wipers are interconnected with a regulator, you will need to listen closely to see if you can hear the motor running when you turn on the wipers, if so the link for the regulator has failed. check this first.
Mark (mhpautos)
Dec 23, 2009 at 10:17 AM
