1991 Acura Integra TIMING BELT REPLACEMENT
OLDLADIES57
  • 1991 ACURA INTEGRA
Engine Mechanical problem
1991 Acura Integra 4 cyl Front Wheel Drive Manual
MY TIMING BELT WENT ON MY CAR WHEN I WAS DRIVING AND I WOULD LIKE TO KNOW HOW TO REPLACE IT AND COULD THEIR BE OTHER PROBLEMS THAT COULD HAVE HAPPENED AND WHAT SHOULD I CHECK FOR
Friday, July 24th, 2009 AT 1:28 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Your vehicle is equipped with an interference engine. This means, if the timing belt breaks during operation then it is highly likely that there will be severe damage to the internal parts of the engine. The valves and pistons are most likely bent now so the engine will need a overhaul or replaced.
Friday, July 24th, 2009 AT 1:39 PM
