shaking, vibrating of steering wheel when applying brakes
ACURA CL
DONALD.GLASS
97 Acura, 3.5 with 143,000 miles. The problem I am having is that when you apply pressure on the brakes you feel a shaking or rough vibration in the steering wheel coming from the left front brake area. I have had the brakes replaced and I have had the Acura dealer do a thorough 45 point inspection and the only thing that they noted was that I needed a r/f caliper replaced and i have had that done but the real issue is on the left front area. What do you think the problem could be?
Aug 27, 2007 at 5:14 AM
BRUCE HUNT
  • 3,754 POSTS
Same as the other side. It sounds like a caliper that is warped. Even after they get turned at the shop they are thinner and heat will more easily cause them to warp. Replace with a new one and your problem should dissapear.
Aug 29, 2007 at 9:17 AM
