after some time, ran another diagnostic and it said that everything was fine, but the lights on the cluster continue to give the same problem. Can you please give me some kind of idea as to how to fix this problem. Thank you kindly.
I also have a compustar alarm system with an auto start feature which has not been starting as of a couple of months proir to this problem. Would that have anything to do with the problem as well. Thank you kindly.
SPONSORED LINKS
Friday, July 18th, 2008 AT 10:33 PM
