MY 98 ACURA CL WHEN STARTED IDLES HIGH AND LOW CONTINOUSLY. WHAT IS CAUSING IT TO DO THAT
Tuesday, July 22nd, 2008 AT 8:11 PM
KHLOW2008
MECHANIC
Hi JAYWILZNY,
The idling system is malfunctioning and you need to check
1. If the coolant level in radiator is correct.
2. For clogged coolant hoses to and from IAC.
3. For vacumn leakage at intake manifold.
4. If throttle body and IAC requires cleaning.
