1997 Acura CL Solenoid
LINDA LAIRD
  • 1997 ACURA CL
  • 4 CYL
  • 300,000 MILES
Diagnostic test shows that the solenoid may be bad. How much should it cost to replace it and how difficult is it to do?
Monday, September 27th, 2010 AT 8:54 AM
WRENCHTECH
  • 20,761 POSTS
That car probably has 50 different solenoids for various systems. You need to be a lot more specific than that.
You also need specific component testing to even determine if the solenoid itself is the problem.
Monday, September 27th, 2010 AT 9:01 AM
LINDA LAIRD
Thanks for your reply. This is my son's car. He had diagnostics run on it because the "check engine light" came on. The three codes that came up were:
check transmission fluid - it was okay.
Check connections - they seemed okay too.
Check transmission solenoid - the reason for my question.
I am fairly ignorant about these things but I hope this is enough information.
Monday, September 27th, 2010 AT 9:13 AM
WRENCHTECH
  • 20,761 POSTS
I'm sorry, there is no such information stored in the car's computer. That is personal advice someone decided to put into the report. There will be a 5 digit code number starting with "P" and even that is just a reported malfunction that would still require specific component testing after getting the code number that would isolate the area of concern.
Monday, September 27th, 2010 AT 9:19 AM
LINDA LAIRD
Thanks for your help. I will pass your information along to my son.
Monday, September 27th, 2010 AT 9:26 AM
Related General Content
