1997 Acura CL IDLe
1997 ACURA CL
VENTURAE4
Other Category problem
1997 Acura CL V6 Front Wheel Drive Automatic 146578 miles
To whom may be able to help me: My Acura has been sitting for 2 1/2. Once i started it my RPM keeps idleing from 1 to 2.5 on its own. I warmed up the engine before i drove it and while driving it keept idleing. What do i need to do? thank you!
Dec 2, 2007 at 6:33 PM
BRUCE HUNT
  • CAR REPAIR CONTRIBUTOR
  • 3,754 POSTS
I would check the coolant level to be sure it is full. Then warm the vehicle up and crack open a bleeder on the cooling system (anti-freeze) and let out any air in the system. The temp sensor can read inproperly if air is in the system and fool the computer into pushing extra fuel in.
Other items to check include:
IACV might need to be cleaned
PCV could be stuck
EGR valve could be in need of cleaning, repair, or replacement
Leak at a vacuum hose
Leak at the intake manifold or intake manifold gasket
Dec 6, 2007 at 10:36 AM
