1997 Acura CL front Rotors
190,000 MILES • 4 CYL • 2WD • MANUAL
JUICENJOHN
I changed my rear rortors and pads with no problems, but when I go change my front Rotors the front hub does not want to come out where the tires are screwed on. so I cant removed the hub and therefore the rotors cant come out. I saw something online saying I need a press to remove the hub. I used a puller and its still not coming out. I removed the control arm and linkages in the bottom and found 4 screws behind the rotor so I removed them and that did nothing. So my question is how do I removed the front rotors on my 97 Acura 2.2CL.
Oct 28, 2008 at 3:27 AM
KHLOW2008
  • 41,812 POSTS
Hi JuicenJohn,
After removing rear the 4 pcs of bolts, you need to tap the bearing assy out. Nut back the screws slightly and use a mallet to knock the bolts evenly across to get the bearing assy out.
Oct 28, 2008 at 9:13 AM
