1997 Acura CL check engine light on sayin mis fire in cylnd
DADDY11284U
  • 1997 ACURA CL
  • 4 CYL
  • FWD
  • 20,539 MILES
Here is my problen when I pull off and go slow to about 20 mph as if I was creepin the car sputter. But if I drive fast nothin happens only when I'm goin slow. I change the distributor, coil, the wires, plugs, fuel filter the computer and next is gonna be the wire harness pleas tell me what I can do I'm spendin too much money already
Friday, April 2nd, 2010 AT 5:34 AM
Engine running rough or misfiring can be cause by the following-inspect and test all the following below:
1. Defective spark plug.
2. Inadequate spark/coil, defective spark plug wire.
3. Lack of compression
4. False air leakage.
5. Faulty fuel injectors.
6. Insufficient fuel pressure.
7. Contaminated fuel.
8. EGR valve that is leaking.
9. Oxygen sensors.
10. Idle air control valve.
11. Throttle position sensor.
Friday, April 2nd, 2010 AT 5:40 AM
JOHNPARKER99
  • 5 POSTS
Contaminated fuel is one of the reasons for this problem. As rasmataz has listed you will need to so some RnD to find out the exact reason.
Tuesday, April 6th, 2010 AT 10:17 AM
