1997 Acura CL
CARITATHOMAS
  • 1997 ACURA CL
1997 Acura CL 193500 miles
My abs light comes on when I go 70 mph and my srs light is on all the time, what could be causing these problems. Also when I hit a bump the left side under the car makes a streaking noise, could that be my shocks. Thanks 4 your help!
Tuesday, February 3rd, 2009 AT 6:40 PM
F4I_GUY
  • 3,302 POSTS
You need to get your ABS and SRS system check for trouble codes. There are a lot of possibilities as to what's wrong with the vehicle.
As to your suspension noise, some items to check would be, balljoint(s), stabilizer end links, stabilizer bar bushings, broken coil spring, noisy strut, etc. Basically give the front end a good check over. First thing I would check would be your stab. Bar endlinks, they are pretty common.
Monday, February 16th, 2009 AT 7:47 PM
