Accelerator increases without pressing the gas pedal
2000 BMW Z3
130,000 MILES • 1.8L • RWD • MANUAL
SMILLYBIFF
Twice now whilst driving at the speed limit I have felt the car increase in speed. I have taken my foot off the accelerator and it continues to speed up. I took it out of gear and the rpms went to 6000. Because of the road i was on I could not pull over immediately so had to constantly brake to keep the car under control. After ninety seconds I gained full control of the car. Whilst all of this was happening I was pulsing on the accelerator incase it was a sticky pedal/cable. But since reading forums I understand this could be a bigger/costlier issue than some WD40.
Jan 4, 2017 at 9:08 PM
  • 31,937 POSTS
Defiantly a very dangerous situation to find your self in, i can't see anything in the TSB for your problem, it sounds as if it is cruise control or engine management problems, this should be sent to a dealer ASAP for a scan and report.
Jan 7, 2017 at 3:00 PM
SMILLYBIFF
Thanks for the reply. I forgot to add that the car doesn't have cruise control. However I did find the accelerator cable at the engine end was very slack at its fixed point.So when I put the foot down it took up tension but when I released it didnt always reset itself. I have since tightened up and Im monitoring the situation.
Thanks again
Jan 8, 2017 at 12:27 AM
  • 31,937 POSTS
ok, but be careful, something like that can be dangerous, i would still call a dealer to see if they have had this problem presented before.
Jan 8, 2017 at 4:52 AM
