Accelerator failure
58,000 MILES • 2.8L • 6 CYL • RWD • MANUAL
VON KEOMAXAY
When I take a corner or loop the accelerator goes all the way down to the floor without the engine revving or accelerating. Once the car is straighten out the accelerator is back to normal. Please help explain what the problem maybe. Thanks!
Sep 26, 2017 at 12:51 AM
  • 55,746 POSTS
Its sounds like you have a throttle sensor that can be out. Does it have a check engine light on? The first thing we should do is pull the codes, Here is a guide that will help you get the job done.
Please let us know what you find.
Cheers, Ken
Sep 27, 2017 at 5:57 AM
