acceleration
149,093 MILES • 6 CYL • AUTOMATIC
LOVEBUGWHIT3
the car will go real slow like it does not want to accelerate when i start to drive but then pick up speed later on. every time i slow down to stop or turn it does it again slow down the pick up speed. i went to a auto place to get a diagnose and gave me codes c1223 c1224 c0300 p0404 p0502 p1189. i do not know what the codes mean. can i get some help please?
Apr 17, 2017 at 12:00 AM
HMAC300
  • 48,601 POSTS
c1223/4 are wheel speed sensors, but you have to know which one they are so a mechanic is going to have to check there is no code c0300. the 404 code is the EGR valve is sticking which cannot be repaired and EGR valve has to be replaced. 502 is vehicle speed circuit is low which may mean a speed sensor and 1189 is oil pressure problem which can be a short or low on oil.
Apr 17, 2017 at 12:34 AM
