A/C vents passenger and driver side?
100 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
PERCY
Passenger side vents blow nice and cold Buick Park Avenue ultra climate control all the way to the cold. driver side vents don't blow as cold big difference in temperature, but they seem to catch up later but still not the same temperature as passenger side high side compressor 175 40 on the low side thank you for reading.
May 26, 2024 at 9:09 AM
  • 110,248 POSTS
As far as the readings, what was the outside temperature when you checked? Also, it is possible that the ductwork is longer for the driver's side and may take longer to fully cool.
Let me know if this is something that just started. Additionally, with the dual climate control, you have two blend door actuators. There is also a chance one isn't as responsive as the other.
Let me know as much as you can.
May 27, 2024 at 11:39 AM
PERCY
Okay, OEM AC compressor Delphi... Needs change out evaporator and condenser.
May 27, 2024 at 12:12 PM
  • 110,248 POSTS
Thanks for the update. If I can help in any way, let me know.
Take care of yourself.
May 27, 2024 at 12:22 PM
