T
190,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
SIRSLICEY
Jun 13, 2020 at 8:09 AM
Good evening,
When you recovered the Freon, how much oil did you recover? There should be little or no oil recovered during recovery.
I would only add 1 ounce of oil to the Freon system.
https://www.2carpros.com/articles/re-charge-an-air-conditioner-system
The compressor holds 7 ounces but that oil has no connection to the Freon system.
I would evacuate it for 45 minutes and then charge.
When you do that, can you give the high and low side readings to see if the system is working correctly?
Jun 13, 2020 at 9:33 AM
