A/C system not blowing cold air
2006 JEEP COMMANDER
130,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
CHEWYBEAR91
This vehicle does have rear air. To start we had a badly leaking condenser and a weak compressor replaced both and a new dryer. A day later refrigerant leaked off again and using a leak detector narrowed it down to front evap core. Pulled dash replaced core put system back together now it blows kind of cool but not really. Sucked down the system again and recovered all the Freon. Now i'm lost.
Jul 22, 2020 at 2:48 AM
Good afternoon,
What are the pressures on the high and low sides while the engine is running?
https://www.2carpros.com/articles/air-conditioner-leak-detection
How much Freon did you install?
How long did you evacuate the system?
https://www.2carpros.com/articles/re-charge-an-air-conditioner-system
Jul 22, 2020 at 3:24 AM
CHEWYBEAR91
Low sides around 40 high sides around 160. with the engine running did a vacuum on the system for 15 minutes with a 5 minute leak detection nothing after putting in 2.13 pounds of Freon in the system the line gets really cold and then goes lukewarm.
Jul 22, 2020 at 8:47 AM
The low side is too high. It should be 25-30 pounds rock solid.
You need to vacuum it for at least 35 minutes to boil out the moisture. It looks like that is your issue.
Jul 22, 2020 at 9:09 AM
CHEWYBEAR91
temperature, will try. thanks sir!
Jul 22, 2020 at 9:14 AM
You are welcome.
Always glad to help.
Jul 22, 2020 at 9:22 AM
  • 55,399 POSTS
If I can give my 2 cents, the low side should be at about 45 and the high side at 230 psi in about 90 degree weather.
Jul 22, 2020 at 1:56 PM
