A/C not cooling properly
169,000 MILES • V6 • 4WD • AUTOMATIC
AMANDA65
My daughter's car had only cool air coming out of vents. The compressor was making a rattle noise so we replaced it. The A/C is still only cool air not cold. The mechanic wants to put a condenser in now. Could it be something else? I hate to keep doing repairs and not getting her A/C to work properly. Help
Jun 23, 2020 at 11:48 AM
He needs to check the high and low side pressure in order to determine what the issue could be. I assume he has already done this so we need to know what they are when the engine is running and A/C is on.
Let us know this info and then we can take the next steps based on that info. Thanks
Jun 23, 2020 at 12:04 PM
AMANDA65
not sure what they were but yes he checked that and said good. Freon levels were good as well.
Jun 23, 2020 at 12:09 PM
AMANDA65
also he said condenser comes with dryer. just hope this is the fix.
Jun 23, 2020 at 12:11 PM
STEVE W.
  • 15,411 POSTS
You said it had a rattle, did the shop mention if the system needed to be flushed to remove debris? A failing compressor can put a lot of junk into the system that gets trapped in any tight places like the dryer and condenser. Sometime a good flush can clean it out but it doesn't always work. That may be why he is suggesting replacement.
Jun 23, 2020 at 12:52 PM
