AC off due to high engine temperature message
77,000 MILES • 1.4L • 4 CYL • 2WD • AUTOMATIC
DINI MOTORS
This issue seems to be common with this car. I have replaced both coolant temperature sensors and the thermostat, but I am still receiving the message "AC Off Due to High Engine Temp Message".
What else could be causing this issue? What am I missing?
Feb 21, 2018 at 2:43 AM
DINI MOTORS
Did some further research and learned I had to pull the battery terminal and wait a few minutes. This resolved the message from showing up, temperature gauge is now working, and AC is blowing cold!
Feb 21, 2018 at 3:01 AM
KHLOW2008
  • 41,812 POSTS
Well done and thanks for the input.
Vehicles nowadays are intelligent enough to inform you of faults and record them. Some are able to recheck the system the next time you start up and keep in view previously recorded faults. If the fault do not recur after a few startups (number of times depends on individual manufacturer) , the code is self erased by the engine control unit.
Some manufacturers requires fault codes to be erased before the engine control unit would work normally. Guess you have the latter category manufacturer.
Feb 21, 2018 at 2:19 PM
