AC not kicking in
214,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
DONNIE COKER
Did a compressor change an all the other things as well dryer exc. Charged system. compressor is not kicking in. bypass low psi switch an high psi still nothing. checked all fuses inside an out, went to relay found what pins was what an checked have b+ ground comp and last was key well the key side has no voltage. i can apply voltage and kicks in. so thought okay has to be in head unit. found a used unit tried it still nothing. I was wondering if the body control mod could be a problem or anybody have any other tricks for me to try?
Jun 30, 2017 at 9:48 AM
HMAC300
  • 48,601 POSTS
have a mechanic scan for codes to see if control head is the problem. just yesterday answered a question and found that the green wire leading to compressor was shorted by a clamp on compressor, but fuse kept blowing so may not be your problem.
Jul 1, 2017 at 12:20 AM
