ac not blowing thru dash vents
2002 OLDSMOBILE BRAVADA
155,000 MILES • 4.3L • 6 CYL • 2WD • AUTOMATIC
KTAYLOR19981
ac will not blow thru dash vents but will blow thru all the other vents and vehicle stalls when idle with ac is on all this happened after i changed the battery due to it smoking and being extremely hot
Aug 6, 2015 at 4:49 PM
HMAC300
  • CERTIFIED EXPERT
  • 48,601 POSTS
pull hvac fuse inside car with key on for 60 seconds then reinstall it may reset. if not the actuator is not working.
Aug 8, 2015 at 6:19 AM
