Ac musty smell
156,000 MILES • 0.6L • V8
JAN MACON WOLBRECHT
Ac smells moldy, musty. How to clean it.
Jul 5, 2019 at 3:27 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
One thing you can do that is the most simple involves a can of Lysol. The wiper cowl which is the plastic piece at the bottom of the front window near back edge of the hood is an air intake for the A/C-heater system. After time dirt and leaves accumulate after slipping through openings.After mixing with moisture it can produce a slight smell.If you don't feel like actually removing the cowl to physically remove any debris I would use a full can of Lysol and spray into the cowl openings the entire length.Feel free to ask questions about this if needed.Hope this helps and thanks for using 2CarPros.
Danny-
Jul 6, 2019 at 12:01 AM
