Having an electrical short. Every time I change the 20 amp fuse blows out as soon as I turn on the AC. I am having a short somewhere I just do not know where to start. I have ruled out the horn because we disconnected The AC compressor and the horn worked fine and did not blow out until we connect with AC compressor. Could this be a low pressure switch or a high-pressure switch causing the fuse to go out and the clutch not to engage ?
May 4, 2018 at 4:05 AM
