AC will not take Freon
2008 VOLVO V50
16,000 MILES • 2.4L • AUTOMATIC
WRYA KURDISTANI
Hello guys,
I have tried to refrigerate my car, everything is according the instructions but the refrigerant does not go into the system,I mean it doesn't fill! while I have changed all the AC system last year, I'm sure there's no problem with condensation part?
Could you tell where is the problem? And what shall I do?please!
Kinds regards,
Wrya
Jun 13, 2019 at 5:34 PM
Good morning,
I need the low and high side readings on the system both running and not running.
Does the compressor turn on?
https://www.2carpros.com/articles/air-conditioner-leak-detection
Jun 13, 2019 at 10:21 PM
JIS001
  • 3,412 POSTS
As ASEMASTER6371 has stated earlier, we need pressure readings. You may need to start all over and have the system evacuated, pull a vacuum, and then recharged to proper level with an A/C machine to start off with that as basics.
If there is any type of moisture in the system or air pocket then you will have issues. Unfortunately you would need the proper equipment to do these procedure.
Jun 15, 2019 at 3:28 PM
