Steady ESP warning?
155,000 MILES • 5.4L • V8 • 2WD • AUTOMATIC
STELLA2023
ABS sensor.
Sep 14, 2023 at 10:19 PM
STELLA2023
Are active or passive sensors on my SLK. And what should be the resistive reading on the ohmmeter?
Sep 14, 2023 at 10:26 PM
  • 110,246 POSTS
I believe these are passive sensors. If you have a live data scan tool, you can check to see if there is a signal from each wheel and if they indicate the same speed.
If you don't have access to a scanner, you can check them manually. You will need a multimeter or voltmeter.
Here is a link that explains how to do it:
https://www.2carpros.com/articles/abs-wheel-speed-sensor-test
Let me know what you find.
Sep 17, 2023 at 6:47 AM
