ABS module
210,000 MILES • 5.3L • 6 CYL • 4WD • AUTOMATIC
FARAHW
Does it require a computer to fix the ABS module in my truck? I have lost full compression, but last week. It would decompress then make a noise and then it would decompress again. So i am certain the module is out. Someone said i need a computer to replace the module. Is that true?
Nov 25, 2017 at 8:27 AM
KHLOW2008
  • 41,812 POSTS
For the symptoms you are describing, the problem is not due to a faulty module, more likely a fault with the pump itself. For some vehicle, the control module and pump comes as a complete assembly.
Mar 16, 2021 at 2:39 AM
FARAHW
Pump what pump would I have to replace? I have replaced the calipers, wheelbarrings, and the master cylinder .
  • 55,763 POSTS
Moduals go out all the time in these cars.
Here is a guide and a video to help you get the job done you do not need a computer to do the job:
https://www.2carpros.com/articles/how-to-replace-a-abs-controller
and
https://youtu.be/lUotkKXG9dY
Cheers, Ken
