abs light on
1997 CHEVROLET
60 MILES • 3.1L • V6 • FWD • AUTOMATIC
JAMES VANVOOREN
my abs light is on, brakes pads are good.. fuses are good. i replaced a wire hardness on rear. any ideal why?? thnks
Mar 19, 2017 at 7:22 AM
STEVE W.
  • 15,406 POSTS
ABS light can be a faulty sensor, wire, ABS module and more. The only real way to tell is to read the codes and see what they tell you. Don't bother taking it to the parts stores that scan for free. They don't scan the ABS module, only the engine related items. You need a better scan tool than that. Once you have the code(s) you have a starting point.
Mar 19, 2017 at 12:10 PM
JAMES VANVOOREN
it's in the shop, back rear brake was making a noise, when i taking car to shop the abs light went out, that's weird.. but rear wheel is still making a noise only when the wheel is moving.. replaced back brakes bout a year ago , front brakes look good.. been good car for me..
Mar 20, 2017 at 1:50 AM
STEVE W.
  • 15,406 POSTS
If it went out I suspect it's a bad connection or broken sensor wire. Very common issue. The wires flex a lot and break.
Mar 20, 2017 at 2:20 AM
