ABS light is on, and off when I restart the engine
211,000 MILES • V6 • 2WD • AUTOMATIC
JLIANG246
My ES300 has 211k, and the ABS light is on. But every time I restart the engine, the ABS light is off. And when I press the brake, the brake paddle start dotting, after several time of braking, the ABS light is on again and the dotting stops. This condition last for couple of months until these 2 days, now every time I press brake, the car shaking and sounds like it is going to shut down the engine. It did shut down the engine once.
Is it caused by the ABS? Is it worth to fix it? Can I just disconnect the ABS?
Oct 23, 2015 at 2:03 AM
HMAC300
  • 48,601 POSTS
it has to be scanned for codes to see what is wrong with it. a car that old no one may have equiptment for it any longer. so check around. if you pull abs fuse light will stay on and abs will not work.
Oct 23, 2015 at 2:54 AM
