ABS and Engine light turned on?
101,904 MILES • 2.0L • 4 CYL • TURBO • AUTOMATIC
AJF_
ABS light and Engine light
Hey, my car (a Mercedes B180 CDI) has just suddenly had the ABS light turn on and later the engine light also turned on. When I turned on the car I hadn’t put it in accessory mode before starting it and since it’s a different car then I am used to I hadn’t held the key long enough to start the engine (it was silly of me but I am a learner and I was in the car myself to start it, plus the key had clicked in to the mode before accessories). When I got it started it drove for a few minutes and ran fine till the ABS light turned on which limited my speed (run flat indicator was also unavailable). I parked it and turned it off and back on, I did it the same way as before and the engine light turned on as well after a few mins of running. I had some work done with ball joints and the mechanics looked over the car and said it was in perfect order, so the issue was only starting today. (Extra info, the car gets driven once or twice a week with the battery plugged in the whole time, plus it’s a diesel engine. Could this be faulty sensors?
May 20, 2023 at 7:02 PM
  • 55,721 POSTS
It sounds like you have a ABS wheel speed sensor that is out but to be sure we need to run the codes.
Here is a guide and a video to help us get started fixing the car:
https://youtu.be/Pb6nXV-iamI
and
Please go over these guides and get back to us.
May 21, 2023 at 5:09 AM
