ABS light on?
75,000 MILES • 1.4L • 4 CYL • 2WD • MANUAL
STEVE MIDDLETON
The problem is when applying the brake over slightly rough terrain (bumpy road) the front wheels start to shudder, we lose breaks altogether, ABS lights up, the car will not stop, until I lift off the pedal and reapply it. My son rear-ended another vehicle due to this. I'm sure it's the ABS Impulse ring differs from the original, it came from the OEM agent. Cheers, Steve
Feb 11, 2021 at 5:54 AM
I would agree that it sounds like the ABS is activating so we need to start with checking for codes.
If the wheel speed sensor rings are not correct then we will have some codes that tell us we have a wheel speed sensor issue.
So let's start with that and go from there.
Here is a guide that will help with ABS lights on but I would suggest starting with the codes:
https://youtu.be/Pb6nXV-iamI
It sounds like you may have a wheel speed sensor that is out. These videos will help us find the problem.
https://youtu.be/rTtAnsOlZU4
and
https://youtu.be/ANWVTh2RQoQ
and
https://www.2carpros.com/articles/abs-warning-light-on-easy-repair-guide
Feb 11, 2021 at 11:39 AM
