ABS will not turn off
2011 PROTON SATRIA NEO
91,000,000 MILES • 1.6L • 4 CYL • 2WD • MANUAL
OX69
ABS light wont turn off on the dashboard.
Mar 5, 2020 at 3:53 AM
Unfortunately we don't have specific info on your vehicle because it is not offered here in the USA however, if the light is on then you have codes in the system. We need to find out what codes are there and then you will know which way to go with turning the light off.
Most of the time the causes is a speed sensor issue however, we would clearly need to check codes before replacing parts because it would be a pure guess.
If it is a speed sensor issue, here is a guide on how to test them. You will want to test whichever sensor it is telling you has an issue because it could be a wiring issue so if the sensor tests ok, then don't just replace it.
https://www.2carpros.com/articles/abs-wheel-speed-sensor-test
Let us know what you find. Thanks
Mar 5, 2020 at 7:49 AM
