ABS and brake lights turn on and stay on
60,000 MILES • 6 CYL • 2WD • AUTOMATIC
GEORGE GOBBLE
Sometimes they don't and it depends if the vehicle is parked uphill or down hill.
Sep 8, 2019 at 11:46 PM
Good morning,
There is a fault in the system. There is a code that is set as well. It sounds like you may have a wheel speed sensor that is out. These videos will help us find the problem.
https://youtu.be/rTtAnsOlZU4
and
https://youtu.be/Pb6nXV-iamI
and
https://youtu.be/ANWVTh2RQoQ
and
https://www.2carpros.com/articles/abs-warning-light-on-easy-repair-guide
You can get a parts store to read the code for you for free. Once I know the code, I can help narrow the area of failure for you.
Sep 9, 2019 at 12:27 AM
