ABS
1997 MERCEDES BENZ E320
175,000 MILES
FLYBOY0023
  • 20 POSTS
ABS light on.
Jan 18, 2018 at 5:07 AM
STEVE W.
  • 15,351 POSTS
Could be almost anything from a bad wheel sensor to bad ABS controller. You need to scan the system with a scan tool that can read the ABS system and see what the codes show. MB cars are fussy about scan tools as well, most of the ones that claim to read ABS codes will only pull the generic codes and not the manufacturer specific codes used. For that you need a dealer level tool to get all the codes. That will give you a place to start from.
Jan 18, 2018 at 2:51 PM
FLYBOY0023
  • 20 POSTS
Sorry I did not give much information.
ABS, ASR, brake light on. Speedometer does not work, transmission does not up-shift. Advance AP scanned, said wheel sensor A, said this was right rear wheel. Sensor looks okay, had some metal shavings on it. Found connector under rear seat. When I ohm it, it only beeps for a second, will not stay on continuously. Thanks for your reply.
Jan 18, 2018 at 9:59 PM
STEVE W.
  • 15,351 POSTS
There should be continuity though the sensor full time as it is just a coil of wire inside. Sounds like a sensor failure. The system uses information from the sensors to make the speedometer and the other items operate. On most cars the failure would trigger the ABS light, on the Mercedes they tend to make any failures more noticeable.
I would double check the continuity in the sensor and if it fails replace it. Then have the codes reset.
Jan 18, 2018 at 11:36 PM
FLYBOY0023
  • 20 POSTS
Thanks so much for Your reply, will do as you suggests and let you know if this corrects the problem.
Jan 18, 2018 at 11:50 PM
STEVE W.
  • 15,351 POSTS
Check the ring that the sensor reads as well. They can crack and cause issues as well.
Jan 19, 2018 at 3:52 AM
FLYBOY0023
  • 20 POSTS
Took front wheel off, disconneced connector, could not get an ohm reading on front sensor either. Sprayed brake cleaner on rear sensor and rotor. Reassembled, started engine and drove off, all worked well. Check engine electronics light stayed for few minutes then went off. Not sure why couldn’t get ohm reading on either sensor but all id working well now. Maybe just cold weather. Thanks so much for the help. Will let You know if I have more trouble.
Jan 19, 2018 at 4:18 AM
STEVE W.
  • 15,351 POSTS
Cold could cause it if the connection is poor to begin with. But I suspect it will be back. The front sensors are of the same type so they should also read continuity. There are also brake wear sensors on there, those should not have continuity, maybe those are the ones you tested? Either way if the light went off the error went away. Keep us informed please.
Thank you for using 2CarPros.com.
Jan 19, 2018 at 8:15 AM
FLYBOY0023
  • 20 POSTS
Hi,update on my abs sensor problem. Had a similar problem on harley davidson a couple years ago, engine missed at low speeds, ran good at higher speeds. Harley shop replaced inlet air temp sensor, still had problem, then they found broken wire inside insulation. Explanation, would miss at lower speeds, at higher speeds output voltage was higher and therefore jump the gap and run correctly. Seems like the sensors will not ohm with the low voltage battery power, but will operate with the higher operating voltage. I agree with You Steve, probably going to be temporary. Anyway plan to replace the two right sensors, check the other two and replace if needed. Have two more questions 1- when I reassembled everything the codes went away, why do some codes go away and some have to be cleared with scanner. 2- anyone know the least expensive scanner that will clear codes on mercedes an work on other autos also? Thanks again for Your help
Jan 22, 2018 at 1:31 AM
STEVE W.
  • 15,351 POSTS
Internal wire breakage and internal connector failures are very common, especially with ABS/speed sensors and door/trunk wiring. It's one of the reasons I have about three fox/hound wire break detectors in the toolbox...
Codes -
There are multiple types of code setting criteria, some like the ABS and engine sensors are under constant monitoring by the control systems. On those 99% of the time the light will go off and the code will become a history code as soon as the system powers on and the control system detects that the fault is gone. So if you have a bad TPS sensor that sets a code, you replace it, and that was the problem, the light will go off.
Others are not monitored that close, they may run on a time cycle like every engine start and take 2 fails within 2 starts to set. Those will usually clear themselves after the system runs through 3 or 4 starts without that fault.
Then you have tests that are only run under very specific conditions. EVAP tests are usually that way. They may only run when the ambient air temperature, engine air intake temperature, coolant temperature Fuel level and engine rpm are all in set windows.
For those tests to run there cannot be a fault in any of the systems that are used to monitor the test. So say you have a faulty fuel level sensor and don't repair it. It is very likely that the EVAP tests will never run because the computer doesn't know the fuel level. Say you replace the sensor, now it can run the test, but you also have a bad fuel cap and purge solenoid that now show up as EVAP leaks and set codes! These are the "I took it to the dealer/shop and they replaced my fuel pump but the light just came back on, did I get screwed?" type items...
Most codes will actually clear themselves IF the fault that set them was repaired and the test runs and shows the repair was correct. We use the scan tool to clear them simply because of speed, If the test takes a week to run but we can clear the code and initiate the test in the bay, we can determine if the repair was correct and functional.
There are also codes that will show up as permanent codes that cannot be cleared even with a scan tool. Those are vehicle and system specific.
Scan tool - Mercedes has a multiple tier system with the "common OBDII codes" then manufacturer specific codes that a good after market tool can read and then some that are on the various CAN bus and fiber optic lines that only a true factory tool can read.
For a scan tool that will clear codes and be useful on multiple brands, it depends a LOT on what you want to do and how little you want to spend. Give me a number as a top amount and I'll create a list. Generally the $100-200.00 units will read codes and clear them and may give you some live data but they are somewhat vehicle specific, some will work great with domestics but not imports, others are great with import coverage and lousy with domestics. The next tier up gets better and so on. For bidirectional control and testing you will be looking at something that starts around $800.00 new.
Any other questions just ask.
Jan 22, 2018 at 2:51 AM
