A sputter that's getting worse
175,000 MILES • 6 CYL • 2WD • AUTOMATIC
COLECASARES
Started to sputter, changed plugs and wires, still a sputter, noticed spark coming from ignition coils, changed all three, sputter got worse, very rough idle, hardly drive, while out of town a friend of dads looked at it and unplugged some wire near the breather hose now has a smooth idle even when I give it gas but when I try to drive it won't accelerate and will try to stall unless I let off the gas, could this be a sensor? If so which one? Thanks!!
Feb 14, 2016 at 8:59 PM
JOHNNYT73
  • 924 POSTS
Do you have a check engine light? If so then go to parts store to have them get the code(s) for you.
Feb 14, 2016 at 9:54 PM
COLECASARES
Yep, code for the o2 sensor!
Feb 14, 2016 at 10:15 PM
JOHNNYT73
  • 924 POSTS
What was the code exactly?
Feb 14, 2016 at 10:18 PM
COLECASARES
P1166, p1167, heated oxygen sensor, but I had these same codes since before the sputtering
Feb 14, 2016 at 10:24 PM
  • 55,561 POSTS
We had a Hyundai int he shop the other day and the spark plug were causing the problem, have you changed them recently?
Mar 7, 2016 at 4:14 AM
