A/C temperature problem
180,000 MILES • 3.7L • 6 CYL • 4WD • AUTOMATIC
REA4444
  • 6 POSTS
A/C blows colder when idling, gets warmer when pushing accelerator. Checked A/C coolant level, gauge showed okay.
Aug 15, 2019 at 2:40 PM
STEVE W.
  • 15,419 POSTS
Welcome back. Your description sounds like a failing compressor or a blockage that isn't allowing the 134A to flow properly. For testing you will need an AC gauge set. Put the gauge set on it and then watch the pressures as it idles and what it does as the engine rpm's increase. Once you know the actual pressures you can go farther but you need those first.
Aug 15, 2019 at 6:12 PM
